The Darkside
Heavy Metal Thunder
- May 25, 2001
Would like to see how much boost some of you are running w/93 gas & alchy.
Also,what chip & what fuel pressure(line off) setting are?
I'm up to 24 lbs boost w/Testa's 93 chip(22 degrees timing) for 009's,fuel pressure set @43 line off,but I'm still running very rich(890 down to 825 at the top end).I can't seem to get it the o2's down.It sure seems like running w/24 lbs boost that 43lbs. of fuel pressure wouldn't be to much,but I guess I'll have to lower it down a couple more lbs.
The Darkside
The Darkside
