SignUp Now!IM GETTING CLOSE LONNIE .. IVE GOT MY FINGERS CROSSED THE TRANNY HOLDS UP .. :biggrin:Tom Lorek went mid 9s with a 60-1 back in 1993 when he was racing NMCA.
im beating on it like you own it ... Loldont be scared let it have it.
This turbo is probably from 1993. This car would have that potential if it weighed about 500 lbs less. That's some feat. Idk of anyone who has come close to that. I heard of 10.30's with a pt54 similar turbo with just a 69 ex wheel. With a stator change in the converter, higher CR, slightly smaller cam lobe, and a couple degrees more timing I could see the 60-1 making another 40-50whp and 100 ft lbs more torque than I did on this one. I only made 3 hits on the 60-1.Tom Lorek went mid 9s with a 60-1 back in 1993 when he was racing NMCA.
When thinking about the pressure ratio keep in kind this engine is way more efficient than most. You will be surprisedAccording to the 60-1 map, the max mass flow is MUCH lower than the PR you ran it. (I am sure)
So, . . . . I am going to say . . . with the compressor out of breath . . . peak 603WHP/575TQ, 5500 rpm, 5% slip.
Having said that . . . it is still WAAAAAY of the map. LOL!
After you post the numbers, we will see how clueless I am. :tongue:
Injectors are 3105's. 2 340 pumps at 16v. Idk why that matters. Very small shot of alky, c16. The targets I used are for safety. Not peak dyno numbers or I would be using a target at least half a point leaner.what size injector?what fuel pumps and fuel is being used?
  !  LOL
!  LOLDamn compressor maps!Probably right about me being surprised!
Well . . . If the engine is more efficient, the compressor would max out sooner. . . .
Now, based on my first gut feeling, I am going to say . . . 527WHP, 2.45PR, 66lb/min, 5700 rpm, BSFC 0.55, 5% slip, 50F MAT, 98% VE, 18% drivetrain loss :redface:
Disclaimer: If the turbo supplies more than that, the map is wrong
! LOL
:biggrin:im going to say 612 to the tire.
im going to say 512 to the tire.sorry wrong button
Yup. Remember when I said THS was a 9.3-9.4 class? Well it isn't. It's a 9.2 class. I wonder if it will evolve in the next couple years?
Not going to happen. The expense of building an engine to compete in a couple races and the proximity of races makes it a no go. If it was 10 years ago and there was some class racing that was closer id consider it but i cant justify the time and expense in my mind.Why don't you field an entry and show people how to do it?
Thanks, Kip
