SignUp Now!Originally posted by d0n_3d
you need way more than that...
slicks = $300
that TE-60 will not get you in the tens...try PT-61 = $675
57 lb/hr high impendence injectors = $360
boxed lower controls arms = $220
moser axles = $300
ported and polished STOCK heads w/ valve job = $700
3200 stall converter = $300
double pumper fuel pump system (i wouldn't chance a single pump in the 10's) = $500
beefed up tranny = $2000 (to make it bulletproof)
i know for sure i am leaving out some things...but it costs way more than just a couple grand to get in the tens...oh and i wouldn't be trusting a $175 cam...try a $1000 billet roller cam...
Originally posted by V8killR4U
In addition to what I have at a minum what will i need to run 10's
Heres what i thought
I was thinkin Iron Heads $1200
50-72lbs INJ $445
Slics $340
Cam $145
Labor $500
Air bags $69
$2699
well assuming your motor hasn't been touched...you can't just run 10's on a stock motor...you need to at least port and polished the stock heads, get a valve job done on them, and port match the intake...
and to put everything on the ground...you need to spend at LEAST $500 on the suspension...ATR rear sway bar, boxed lower control arms, air bags, Bilstein shocks, etc.
