HRpartsNstuff
- May 27, 2001
Sorry if that got a little confusing there, haven't had time to put that step into the instructions permanantly vs the separate sheet add-on.  The large OD flat washers should go between the lower axle brackets & the gold clamps for the poly.  The idea is that the poly was designed for a 1-1/4" bar, but with the powdercoat being nice & thick (not just a quick cover coat like most others), it gets a bit tight on the poly when clamped tight.  The washers take a little tension off there & let the bar move a little more freely.  You could leave them out & probably still work ok, that is how we made the kits for the first year or so.  The poly & the powdercoat is so smooth & with the grease there, it all moves pretty smooth even without the washers.
Now if you have the other smaller od flat washers in there, I would say you need to take them out & swap with the large OD washers. The smaller od flat washers should go on the bolts with the lock washers. That should go: bolt, lock washer, then small flat washer.
Enjoy!!!
Enjoy!!!
