you may want to upgrade the rubber hoses to E85 compliant pieces
They,already,are.
I thought the dw pump was too large to be used with a double pump hanger and still fit in the tank? Has someone tried this yet?
Hmmm...2 DW pumps sounds interesting. I wonder if anyone has tried it?
the racetronix double pumper rocks!Thoughts about the Racetronix double pumper unit?
Again,I don't recommend this. I would want a lower volume pump as the first pump.
I don't like the way they connect the flow of the pumps together with a block. Red uses a Y tube. Red disables the pressure relief valve so it can't come open. This means the pumps will produce maximum pressure. The time that the relief valve is going to open,lowering pressure,is at the worst possible time. Up stairs.Thoughts about the Racetronix double pumper unit?
Why don't you recommend "this"?
............Why do you recommend the DW? Because you sell it. You'll defend it until gasoline is coming out the crankcase vents,then you'll advertise that it comes with a waterfall attachment at no extra charge. ............
I would not use or recommend a double Pumper.. just get a bigger pump all together and use new lines and do it right the first time so u can grow into it.
Ttype6 said> Thats kind of harsh bro....Nick is as forthcoming and knowledgeable as we have here.
So no mods to fuel line with DW pump?
I sell the DW pump because it is the best pump in many areas, NOT because of the few dollars
If you had personal experience with installing and evaluating a few DW pumps, your statement and "recommendation" may had have had some validity?
I prefer to deal in facts and results, good or bad, in my "recommendations" as well as the products and services I provide.
I deeply resent your comment my integrity.![]()
