SignUp Now!TurboBob said:if the heads are still on you can still leak it....
Bob
turboclam3 said:So is an exhaust valve not opening (carbon) while spraying alky (clean rear ports)? Did it have an RJC plate? I'm not good with reading between the lines.
What cam? How much boost? Too much backpressure.
Been following your post over at speedtalk. Was there a decision on what's happening with it?
Was the EGR blocked off on this car?
WHat do you think happened in your opinion?I asked this before but got no response.
Curious, what is the reason that your tearing this motor apart for?
