greeneyegi
- Feb 21, 2010
its 4.2 powerlogger.
SignUp Now!i just found a log from when it wouldnt stay running because it seemed flooded,and the whole time its .443 even after it starts to run(crappy)for a few seconds its .443it looks like the ECM is resetting (rebooting), if you look the stock O2 gets momentarily set to .443 which happens at reset.
im not sure whats causing that though. what version of the sd2 are you running?
Bob
Ive had powerlogger for years now.started with the 5.7,6.1, then the sd1.I didn't start having the problem till the sd2.Sounds kind of like what I have been chasing since 2011 after I added the powerlogger. I have active threads on here about it as well.
yes,ive done both.everything seems ok.i have another computer and tried to switch the powerlogger and chip but couldnt get any data to go through that one.all of the data was 0.put everything back and back to square one again.have you checked the pins going to the ecm on both plugs .have you reseated the prom .i dont own an sd2 but have a maxeffort and found a problem in the past with these items
hers the file the iac counts are 0.then all the sudden the car revs up by itself and the iac starts counting again.
yes that sounds like a good idea,at least i can eliminate that thanks.shoot an email through your tt website?In that file, you shifted from park to drive. It doesn't look like it happened randomly.
The ECM is resetting at WOT for some reason. I can send you another chip to try out, in case something weird is happening there.
On the spark advance issue, I'm not sure what you mean there. Are you saying when you add spark advance on the big spark table?
If you want, send me an email, and maybe I'll have you send the PL board and chip to me, and I can check it out.
Eric
cool just sent.
when i put timing on the tune page,parameters,timing reference adjust,i get very weird trouble codes under wot.In that file, you shifted from park to drive. It doesn't look like it happened randomly.
Eric
your probably right,but my thinking behind the adjustment is its their for cars that are off on the initial timing.which is why i messed with it in the first place.i didnt find anything anywhere on the sd2 chip online discussions or in the book,that would explain it.so like always im experimenting with it.and thats what happens in my situation.hopefully someone else that has adjusted this setting can chime in and say that it shouldnt throw codes that never came up before the adjustment and never comes back after putting it back.I could be wrong but..... I don't think you need to be messing around with the "timing reference" adjustment. That adjustment is only there to be tweaked if you balancer is out of whack. If you want to make timing changes you should make them on the big timing table!!!!!
