Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
Was reading a few post and got motivated by many of you. . . . So, I got the block back together.
Short block was assembled by the machine shop. Motor was running fine before I took originally it out, i.e. 20PSI hot oil pressure with 5w30 in +100F weather. The thrust was at 0.014”, and oil pressure had dropped 3 psi, so I took it out.
Fast fwd +12 months; Block went to the shop to install billet mains, and freshen up, squared, mag'd, deglazed, rods resized, etc.
The first time back, it ran 10 minutes "no load", and oil pressure dropped from 50 to 5, so I took it out.
I saw bearing material in the filter, but the shop said "everything looked good". (Hmmmm . . . .
Block is back, the second time, from this shop, Specs; 109, 10/10 crank, Main/rods = 0.002/0.0022, FT roller cam / Morrel lifters, HV pump, blah blah.
Please take a look at the video, and let me know what you think it is.
FWIW:
When I did my "homework", the shop has done quite a few 109's in the area, including some S2's.
Appreciate any feedback.
FWIW:
