My car has a SMC dual nozzle progressive alky kit. Usually I can run 22lbs of boost with 93 and no knock Te 62 turbo, cas front mount ic, TT alky chip 5.4 version 24 timing in 1st and 23 in second in third. The weather here in the metro detroit area has been very hot upper 80's low 90 with high humidity. At 22lbs I'm pulling 4 degrees of KR at the shifts. Will higher weather temps cause this??? I have the system pump turned to 10 ( highest setting) o2 volts look good 790 to 810 a little rich. Any input would be appreciated
