three turbos
NUNLKME
- Oct 17, 2010
Ok yesterday took my 87 turbo-t out (107,000)miles on it and noticed 5.6 kr in 3rd at wot so obviouseley i lifted i plan on starting by checking all the readings on my scanner (o2,iac,tps) to start but im sure there fine car runs and start great my fuel pressure is around 43-44 line off however i have never checked wot pressure with the external gage so im thinking after settings check on doing that first and double checking my o2 readings at wot any input guys? (mods are 009 injectors42.5lbs,cold air kit, tt5.6 chip,3000 stahl converter,hot wire kit, adjustable reg.,2.5 hooker exhaust,3" down pipe,ta49 turbo set at 17 lbs, running on 93so am i heading in the right direction? Eric
