- Feb 18, 2006
I don't understad why so many problems with this. Mine has worked flawlesly for a couple years now.
Have you tried to reset the controller? Unplug the o2 from the harness then power up the controller (turn key on) for 60 seconds. Turn key back off, re connect the sensor then re calibrate.
They say don't wait for senor to heat to start the car. It's better for the exhaust to heat up with the sensor.
Are you running a gasket from the turbo to the downpipe? Make sure your downpipe is not for some reason isolated. It should have a good ground to the motor.
Where is the controller located?
An AFR of 22.1 is normal during heat up.
