Finished up my Hurst line lock install tonight.
My problem is, with a nice firm plant on the brake, line lock engaged, pedal released, the front brakes just dont seem to have enough clamping force to hold, and the car just pushes right through after easing into the throttle only a little.
Now it is on a concrete driveway with 275/50 M/T drag radials, but I would think I should still be able to brake the rear wheels loose without the rear brakes holding them.
This considering before I beefed up the rear brakes, I could power-brake burnout easiliy without overpowering the front brakes. The only thing I can think of is maybe re-bleed the front brakes? I forgot to hold the button on the combination valve in when I bled them tonight, but didnt think that was a big deal.
Replaced calipers several months ago, and new brake hoses tonight. Front brakes just seem to be weak. What gives?
