jasjamz
THS Racer
- Sep 30, 2004
Here is my opinion...
NLU can build more heat in the fluid under normal driving conditions. This is not good for longevity. It will require you to add a better external cooler and decrease fluid life a little depending on the type used. A lock up type converter has more components that can fail. If you are not looking to kick some a$$ everytime you drive the car, and don't plan to put on the track frequently a NLU is not what you need. A good unit will cost you $700-1000 for either type new.
