SignUp Now!I used a 6680 because that's what I had. Not because it was the best scenario. I'm going to start a thread in a couple weeks that will blow the backpressure myth out of the water. Basically a 65 trimHe'd run the number with the 7168 or the 6768. What wrong with using those? You used a 6680 on your black car when you wanted nines right. Less back pressure with the q-trim wheels correct right? Spooling will not be an issue for him.
Not the same. The TA/TE62 is a different turbo.I gotta ask here. Is the 6265 the same as the ta/te62 bison?
Does anyone have any experience with the new 6768 or 7168 DBB CEA wheels and if so, what kind of combinations and et's are you running?
My $.02 on these. I've already seen the 6766 dynoed and have made about 30 pulls on one of my own engines with a 6265. One thing for sure is that the turbos weren't tapped out on either engines and both made 9 sec power under 30psi. It is unlikely that either would pick up more than a couple % with a 68 turbine which is considerably heavier and has already made over 1000hp on a tsm engine. Very few That buy these turbo have enough engine to swallow them. That's why all the lackluster times are posted with them. You need to have the engine and run it hard to make the power at low boost. Switching to a different turbine isn't going to do dick for 98% of those posting here.I may be behind.....but the latest buzz is the CEA exhaust wheels.....and they have recently released the 66 mm wheel which is for the 62 and 67 turbo I think. I understand the 6765 and the newer 6766 is a "small shaft" turbo.....and the 6768 and 7168 is a "large shaft" turbo.....
It is my opinion that the 6766 should possibly make the same or more power than the 6768 did....and spoolup considerably sooner. I would also think the smaller shaft reduces rotating mass a little giving it an advantage too as compared to the older 68 exhaust wheel.
IMHO, the 6766 billet is one bad turbo....and IMHO....might make low 9 sec power with the right combo....but ought to run high 9's on relatively low boost (less than 25 psi)....and be fairly street friendly.
Hey Brian, what kind of hp numbers did the 6766 make and was it on a Buick V6?
Is is safe to say that all of these Billet turbos 6266, 6766 and 6768 would all be close in HP figures when run hard with lower boost numbers (18-22psi) on a good flowing combo. IE: 9:1 compression, roller cam and ported aluminum heads with supporting equipment? Thanks
Datar
With this 6766 Turbo what A/R would you suggest .63 or .82? and would you run a T3 or T4 housing? What compressor housing an E-3/2, S-4/2.5 or a H-4/3 ported or unported? internal or external waste gate?
when you have enough engine and run enough boost to run 137+ out the back there will be some benefit. I know of only about 5 real street cars that have that much power. Buy it with whatever cover will be easier to use.With this 6766 Turbo what A/R would you suggest .63 or .82? and would you run a T3 or T4 housing? What compressor housing an E-3/2, S-4/2.5 or a H-4/3 ported or unported? internal or external waste gate?
If you're planning on making the solid 9sec power that turbo is rated for you shouldn't need to open the hole. If you want to try and turn it down you will need to open the hole. So if you planning on running 10.0 or 9.9 you will probably need the hole opened a little. If you are looking to run 9.7 you should leave it alone. If you want to run 850hp one day and turn it down to 600hp the next day you will need to rethink your wastegate setup because its not going to work with the stock style external gateBison are you suggesting not to port the waste gate by pass hole on the 6766?
