If the car is running with no apparent ignition problems and you have the appropriate amount of fuel to achieve your target AFR and you have boost pressure and if you have no intake/exhaust restrictions then I would say the engine is not moving air. Boost pressure is not an indicator of air flow, but simply manifold pressure of trying to get into the engine.
If everything is checking out like you are saying I would be looking at the engine mechanically for something amiss, such as wiped cam lobes, valve springs that are not up to the task. I know you said you replaced those, but they are critical to the engine and it's ability to perform to it's full potential. Plus at least a compression check.
