- May 28, 2001
Let me guess....At the ft, behind the t/body?the intake to upper plenum seal blew out for about the 100th time.
SignUp Now!Let me guess....At the ft, behind the t/body?the intake to upper plenum seal blew out for about the 100th time.
Yes, there and the back passenger side.Let me guess....At the ft, behind the t/body?
I even tried a Remflex seal and tried everything from stock torque to Remflex's instruction to tighten to 50% squish, to bolts about to break. I even tried the Remflex seal with RTV, always the same result of vacuum leaks followed by no boost. The intake has to be not even close to being machined right. I even measured out new bolts that were not long enough to bottom out. This has been an ongoing nightmare for 38 years.Couple options...
Confirm plenum bolts are tight and no one inserted longer ones and it slightly bottoms out. I got my intake back all messed with and didn't notice until I sold it.
Take your plenum off and have it measured, maybe it's that casting. This then can be milled flat again or just buy the aftermarket one and measure that. From here you'll have an idea if it's your intake too but at least you'll have 50% of the issue covered etc.
Regardless, maybe a double gasket would help with any casting that's off and keep you tight.
Yeah, I could have Brian Cotton take a look at it. I just didn't really want yet another giant bill. I've never had another vehicle do crap like this before. Most other stuff that I've used right stuff on before, I don't want to have to take it apart because I usually would need a hammer and prybar on it. This though, just will not stay sealed.Ouch you've done a lot...
I hear ya on just stopping a constant issue that's just winning after so many attempts, $ and time. Someone could weld the intake to plenum (my Champion is also 2 piece so that's not worth it) and that'll stop the leak, just make sure to add the power plate or whatever IAT etc things to it and then that problems solved. Hahaha
You might wanna step away, have a good turbo or resto shop pull the intake, plenum, measure and machine both etc and just not deal with this anymore. Losing another year of driving vs $1000 might not be good since there's only so many total years to drive these.
No, I have an aftermarket boost solenoid controlled by the ecuGN.As suggested turn boost down to 17ish Do you have a quick spool manual boost controller(like the RJC one)? What is the timing #s on the 100kpa line on the timing map?
that a odd timing table
my TT chip idles 27* ,(39* at 1700 at 40 mph) at (60 mph 1900rpm cruse 40*) at WFO 23.5* 1-2 gear, 2-3 gear 21*
You need to take a closer look at your timing tables Im not furniture with ECUGN but Holley timing table is not linear
post a pic of your base timing table the big square graph with all the funny colors
Im going to need to down load some software to look at your fills on my windows computer I'm a MAC person with just windows for my power logger
Yes, Eric set up the initial tune.^^^
I see the same thing
Chuck likes KPA Im a PSI person I believe more and more have switch to KPA but work with what you understand best.
Did your ECU come with an Eric M tune?
If your running a 3 BAR Map no need to exceed 30 PSI
Most Buicks no need to Buzz them over 6000
I'd have to let some of the tuners chime in on that.Isn't 16 inches of vacuum at idle a little low for stock internals?
