ls 4.8 twin turbo build
Installing the 4l80e transco hd2 shift kit and dual feeding direct drum
Any good suggestions on converter choice for the 4l80e in 10 inch ?
checking out the exhaust..will probably even out the driver side to match the passenger...
Thinking of having both turbos exhaust housings face passenger fender to run both exhaust
pipes to passenger side 2 into 1 for my single exhaust
Tci flex plate with arp bolts installed
Also installed starter
Looks like I may have to take off starter to install converter bolts..
Tight clearance between flex plate and engine
Very nice write up man, im subscribing to the thread. Have a friend doing a NA 4.8 in a 84 monte ss its HER car so no turbos for her HAHAHAH
Why the z06 cam and not the lq4 cam, i hear they are close in comparison.
3 thumbs up!
3 thumbs up!
The zo6 cam was free with ls1 parts ..
This stuff was so cheap I couldn't believe it..
4.8 engine(long block) $250
ls1 heads,crank ,comp push rods,oil pump,zo6 cam + springs,timing chain $250
2008 rods + pistons $75
2008 4.8 crank $75
5.3 short block (spare) $75.00
4l80e (core) $50
th400 (core) $50
Are the 08 rods and Pistons better than the older stuff? I hear you will break rods before rod bolts
That's why I ask. Somewhere around 740 rear wheel on pump gas and 12 degrees of timing
Yes ..the 2005 and up rods are stronger that's why i switched them...
