norbs said:I was being on the conservative side![]()
I wouldn't want to go much over 160mph myself without preventing some of the air from getting under the car. There's mph and stability there with some air redirection. These cars are flying bricks.
SignUp Now!norbs said:I was being on the conservative side![]()
How about some details on the combo?
Congrats Allan, sorry I interrupted dinner![]()
turbobuick said:I never had anything on mine other than the air dam. Its a lot smoother than you'ld think and really not that bad.
Not really anything special. Most everything was off the shelf parts. Some stuff needed fabrication.
Stage 2 on center iron block machined by Bob Bruneau from Bristol CT
4" bore, 3.59 stroke for 252 inches
9:1 compression, JE pistons with special metric ring pack.
Stage 2 heads I picked up used. Still running the same hardware for the last 12 years with exception of the springs.
billet Crower crank was added when freshened for piece of mind
Crower Titanium 6.5" rods, same rods I run for the last 12 years.
CAS fabricated aluminum intake with some small modifications made by me, mostly for fitment.
Modified TA performance high volume oil pump cover with TA performance oil adapter for external oil lines. Modified to clear Gear drive(Another used part I been using for 12 years)
JJ Billet fabricaion oil pan.
Modified ATR headers for T6 Flange turbo
Y2K88 billet wheel turbo(Special thanks to Jack Cotton and Turbonetics for supporting me on this turbo)
CAS V2(I think) intercooler
Camshaft - Selected, reaseached by myself. Will hold back on the specs. Will say that this was a comprimise between durability and power. I do mostly street driving and cruise nights and don't like the idea of changing springs and roller lifters. Camshaft lobe selection made with consulting Bob Bruneau of Bristol CT.
Modified Fluid damper for factory ignition pick-up ring
Stock ignition module and stock replacment Accel coil(Yes they work).
Bob Baily 2 step
MSD wires
Transmission -
Built by me using mostly, if not all CK performance parts with a little of my own flavor mixed in.
CK transbrake, CK direct drum and super sprag, CK billet intermediate shaft, Billet oversized input shaft, CK Direct drum stabilizer. And other modifications made by myself.
Standard gear ratio
PTC converter supplied by Dusty
Fuel management
XFI version 2.10 dyno tuned by Otto
Boost control using XFI closed loop analog 8 and no CO2 - Love this feature and saved me from buying an AMS. May add CO2 at a later date for increase boost range.
Single Aeromotive Pump, Rgulator mounted to drivers side rail(will be upgrading this)
160# injectors
Aeromotive fuel pump controler
Fast/PCS Dash
Fast/PCS Accelerometer
Fast/PCS EGT module
GPS integrated into Fast/PCS Dash
Utilizing 7 of 8 analog inputs and driveshaft speed input
Rear
Strange 9" with 3.90:1 gears
35 spline axles
Reinforced with back brace and oversize axle tubes
Spool
Ladder bar suspension
Front
Tubular upper and lower control arms
Moroso front drag springs
Cheapo lakewood front 90/10 shocks
no sway bar
Body
155,000 original mile car
Bodywork and paint prep done by me
Paint applied by Good Friend Bob Turcotte. We have restoration/hobby shop here in CT.
Allan G.
I would look into the traction control option from FAST, especially if its a street car, and the JMS voltage booster for the igntion and injectors, it would really be a bonus to your combo. Also your data logging is just amazing, never seen anything like it...
I agree and my new car is going to have a rear belly pan and some mods to the front end for this reason.From a performance standpoint there is definitely a few mph there at the level you were running with some body modification.
Allan, what do you have to do to keep from being thrown out of the track if you want to go all out again?
norbs said:Would it not be easier to put a shorter tire on it?
Thanks for the kind words Neal. The 252 thing was an unintentional typo and fixed it now. I'm convinced that there is a bunch left in it. I took some timing out and was only launching at about 11# boost. I think I drop a few tenths at the same boost level.Allan,
Congrats on the ET and MPH. Very impressive! You said you wanted an 8 sec street car and it sounds like you've got one. Performance like this on just your first outing shows you've got a great combo that is well thought out an some good guy's lending a hand where you need them to. BTW, not to give you a hard time but the motor is 270" not 252".
Keep up the good work.
Neal
