Dusty Bradford
- May 24, 2001
After reviewing the logs it's easy to say 8.70's won't be any problem at all. The tune is very soft down low and will make more power up top as well.
SignUp Now!After reviewing the logs it's easy to say 8.70's won't be any problem at all. The tune is very soft down low and will make more power up top as well.
So your sending the converter back to Dusty?
Careful. Very addicting once you get a good taste of it.No, Dusty feels that the converter is right-on. Will need to work on the low-midrange part of the tune. I'm not ever going to bracket race this race so I can tollerate the slow spool.
Can always resort to NOS....
Allan G.
What size rear tire are you running? That pass looked Beautiful!
turbobitt said:31-13-15 MT's.
Tire size worked well with the 3.90 gears.
Allan G.
I am seeing 1000 rpm drop on the shift, don;t you think this is a bit much?
norbs said:I am seeing 1000 rpm drop on the shift, don;t you think this is a bit much?
I'm with Bison. When you start throwing more at it, a higher rear gearset.
turbobitt said:May be a good debate but based on my calculations, at 160 MPH the engine should be about 7150, at 165 MPH engine would be 7400 RPM. Don't really have an idea yet where power will start falling off.
This is calculated given that slippage would be about the same.
Allan G.
Great job car sounds and looks fantastic
