TR Custom Parts
Mark Hueffman - Owner
- May 25, 2001
And he was out driving it on the street tonite!
SignUp Now!Whats the difference between race weight and street weight?Weighed the car today. Scales say 3420#. That makes the race weight at 3650#.
Allan G.
We now know how much Allan weighs.Whats the difference between race weight and street weight?![]()
norbs said:You will have to use a cam with Donnie specs to get the big increases your want. I put small cam numbers in the SIM and still made very decent power, between a 218 cam and 235 cam maybe 40 hp difference max. The power is mostly in the head and turbo, unless you do a huge cam change you might not see big differences.
I have no idea how accurate the SIM is when I just change the cam duration, lift etc, but I have the compression set at a static 9:1 I;ll see if I can post up the graphs. Bison may have a good point, but as we raise compression we get less volume of fuel in the cylinder, but more pressure, kind of a trade off for a street car , but higher boost and lower compression will make more power, so Allan, time to crank the boost up, but then your turbo will be out of its efficiency range. maybe............As stated above, you are comparing at differences between 218 and 235 cams with probably low lifts. Both of these selections are most likley to small to work within the efficiency range of the stage 2 heads and show any considerable gains. Based on what I learned, I wouldn't run anything smaller than 235 cam.
I would predict that I had at least 40 HP gain. Based on comparing ambient conditions of the dyno and track, and cosidering that I pulled timing. I would have expected the car to fall short of an 8 second pass.
If you were to use some of these HP calculators, it would say that the car is making roughly 1000HP to the tires. This would be a 100hp gain over the dyno. I don't really trust the HP calculators but still can't resist looking at them.
Allan G.
norbs said:I have no idea how accurate the SIM is when I just change the cam duration, lift etc, but I have the compression set at a static 9:1 I;ll see if I can post up the graphs. Bison may have a good point, but as we raise compression we get less volume of fuel in the cylinder, but more pressure, kind of a trade off for a street car , but higher boost and lower compression will make more power, so Allan, time to crank the boost up, but then your turbo will be out of its efficiency range. maybe............
That is quite interesting I guess once he turns it up it should wake up.........I guess I will have to do the same boost level to get some power out of it on the 3.8 stage project I'm building.To run the pressure ratio needed to maximize the compressor wheel he's running his 9:1 CR is right on target for a gasoline application. It will likely take boost in the low 40's at sea level with minimal pressure drop at the inlet to get the most out of it. Everyone thinks about the compression stroke when you start talking compression ratios. The ex stroke and over lap needs to be considered. The effective operating rpm will be widened and raised with a higher CR if the cam lobe/timing is optimized. So you could take the engine further even though the cyl pressure will limit the amount of boost that could be run for a given octane. The engines mass efficiency increases quite a bit with a higher CR just from the further minimized time in the dead flow zone when both valves are open at the same time and the piston passes tdc.
