MAF translator Gen II
Rowdy45466
I have a MAF translator Gen II where to use/put the aux/window and Voltage trigger 4 pin?
Where and what do you use the 4 pin conector on the GEN II translator?
Voltage trigger
Also the aux or window switch.
Any help would be great. I also have the wide band kit.
Voltage trigger
Those are optional functions. You don't need need them right now.
Do you have everything else hooked up and ready to go?
Every thing else is up and running. THere is a grey wire on the 10 pin/wire connector that is not used. I did get the car fired up and running. I also got some of the base line set.
Nice job!
Do you know about Full Throttle Tech websie?
Might get more response to your GEN II questions over there.
I don't see a grey wire in my directions. What pin # is it?
I got the MAF translator from Fullthrottle and I was over on their site to get some general parameters.
I'll have to go see what pin the gray wire is.
Rob
