Just like the title says, it I hammer the gas hard from a stop or slow roll and the tires break loose, the car gets major KR out of nowhere at the top of 1st gear and the car starts misfiring bad because of the retarded timing as far as I can tell.  If I let off and get back in it, it's fine.  If I get on it from a roll, it's fine.  If I ease into it from a stop or slow roll, it's fine.  I can stay in it all the way into 4th and O2's stay steady with no knock.
Since I got the problem I have tried...
Different chips
Different boost levels (still does it at 12psi)
Alky and no alky
Replaced:
Fuel pump and hotwire kit
Plugs
Wires
Coils
Ign Module
ECM
Right now I'm thinking:
Is my converter too loose for my combo and it spools too fast for the ECM to keep up?
False knock?
Blown Headgasket?
Electrical problem?
Tired motor is fouling plugs with oil somehow? (I get smoke at startup and idle after heavy throttle)
I'm stumped.
Right now I'm not driving the car because I'm building a shop and then will rebuild the motor, but this problem is still annoying the hell out of me.
Any ideas are appreciated.
Thanks,
Mike
Different chips
Alky and no alky
Replaced:
Plugs
Wires
Coils
Ign Module
ECM
False knock?
Blown Headgasket?
Electrical problem?
I'm stumped.
Thanks,
Mike
  god I hope my car didn't hear that
   god I hope my car didn't hear that 3)smoking when breaking hard-intake manifold leak. which btw may be causing a cylinder to lean out and giving the knock indication.
