- Jan 21, 2007
This is not meant to be a good vs bad comparison between TA Performance SI heads and GN1 Aluminum heads. This is simply an “Out of the Box” look at what your money buys. It should be noted that both sets of heads were purchased un-ported.
The new GN1 heads were at Dave’s shop for another engine build when we started the clean-up work on my TA SI heads. When I say we, I mean Dave. During my work on the TA heads, I documented some visual differences between the two different cylinder heads.
Visually, the TA heads appear to have the pushrod holes machined to tighter tolerances and have slighted larger intake valves. The GN1 head as received have a much smaller lip (almost none) in the valve bowl area under the valve seat. The TA heads have a significant lip in the valve bowl area under the valve seat. My goal on this project was to eliminate this lip on the TA head and improve the airflow
Another difference noticed which may or may not be significant was a difference in the combustion chamber finish. The TA SI heads have an “As Cast” finish. The GN1 heads have a fully CNC’d combustion chamber. You will see this and other differences on the attached slides.
I am very pleased how the TA heads turned out and I plan on putting them on the car in August.
