Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
........I had the new motor built and assembled at RPE. .......
Hey Bryan, Sorry to hear about your troubles.
Did RPE spec/recommend the Cometics?
SignUp Now!........I had the new motor built and assembled at RPE. .......
I am curious to know your results. I have had the exact thing happen to me 3 years in a row with different combos. I will be degreeing my cam next to take out one more variable.
The first time it happened was with stock ported irons, now GN1's. Torched cylinders 1 and 2.
This round added double fuel pumps, egt's in the headers were in the 1400 to 1500 range. Dual nozzle alky, 98 octane this time. Has happened on Vp 109 as well.
Wow...definitely not an issue on how the engine is setup then. I've seen rpe's work first hand and its definitely top notch. Maybe you have an issue in the tune? Is it the same hole each time that's causing it? I've been working on a car that blew a cometic and it turned out #1 and #2 needed additional fuel added into those cylinders through the xfi. No knock was present in the logs either.
Other thing that raises a red flag, why are these fast systems not seeing knock?
Don't forget the XFI software bug that was recently exposed. (non functional knock retard)
Bob
Bob
The box would still display knock, it just wasn't retarding timing. Anytime I come across knock on a car running C16 it is false knock.
Phoneguy: Have you tried logging coolant pressure? It might give you an idea when the problem is occuring.
