Need/want more power!
GNbythebay
Upgrades:
TA49 turbo
Alkycontrol
60lbs injectors
Valve springs
3.5 downpipe with electric exhaust cut out
TT chip
Scanmaster
That’s all I can think of right now everything else is stock on the drivetrain. I just finished upgrading the brake system and now I want more power. I do not wanna spend a crazy amount right now but what would be the next best upgrade? Budget is 1k.
What converter are you running. A TA49 needs a little more stall than a stock converter.
Just crank the boost up have fun while it lasts and when it shits the bed spend the money. Seriously 1k to spend. Bigger turbo 62/62
This X 2
I'm betting you have nowhere near come close to utilizing what you have.. your probably running your setup at 50%
That setup on E85 has gone LOW 11's on the D5 without issue
Fuel pump and Hotwire . Crank up the boost to about 20-22ish with the alky u should be okay and if the turbo isn’t spoiling fast enough then a 2800-3000 stall converter should help it . Just watch for detonation
Take a look through this thread https://turbobuick.com/threads/et-by-dollars.460250/ And pay close attention to my responses.
How fast do you want to go? And how many times do you want to do it over and over and over and over and over and over again?
Don't buy one more single thing for it unless your going to put it in a box waiting for that special moment. What special moment, you ask?
When you blow it up!
Then build the car once in overkill of your goal.
You'll save a ton of money.
to me i remember really enjoying having a bolt on car with a built trans and a good tune and tire.they were fun and you could drive them all the time with capability to run a great 1/8 to 1000ft, good mileage etc.now its nothing like my nt car but it was alot cheaper and required alot less knowledge and effort to maintain.
Id put the grand in the converter before the turbo, the 49 with the right converter feels a lot bigger. it may be enough for you if your only playing on the street and not chasing a number.
Best $500 I spent on mine for performance was tossing the D5 Converter and having Dusty Bradford build me a 10". Way more fun to drive.
