NEW RJC FMIC AND RADIATOR INSTALLED!
Well from what I've read and Peter has told me is that the fans are set up to kick on 1 at a time depending on your temperature so I used the big fan as my main 1 that kicks on 1st. Actually come to think of it I have yet to see the slim fan come on. Lol. The highest temperature I've sen my car get to is 190 degrees. So as of now for me I feel good with the 1 fan on but if it gets hotter in the summer then I will consider wiring them both up to work at the same time.
Are you running XFI? If you are, you have to have the XFI turn on the second one.
No XFI but that is a good tip. I was not aware of that.
Yes you are correct.. Peter said the same thing to me. Mine will be set up the same way.. Last year it was running pretty high.. Near 200.. I just replaced the radiator as well this year and haven't seen it creep over 170, so I should be good.
Posted from the TurboBuick.Com mobile app[/quote]
Here's the view from the front...
Finally.. Slim fan on the passenger side.. Extreme fan in the drivers side!! Works perfect!! Thanks to Rick Lutz and Peter from ALRADCO!
[/QUOTE]
Im running in the low 190's on the highway and 200 in traffic with my new stroker...and I don't like it. I just had my stock radiator hot tanked and i'm running a stock fan with the ballast resistor jumped, so it runs full speed. I'm gonna have to get with Pete and come up with a combo that will bring it back to 175-180. I'm running the XTF-315 intercooler also. I'm very limited on space in front of the intercooler pipes, so this will be tricky.
