Tim Cucci
- May 24, 2001
I just ordered a new Stage 2 transmission from Extreme Automatics. I want to be sure that this tranny gets the correct cooling. I have ordered a Tru Cool 4590 cooler to mount in front of the stock radiator. I prefer to bypass the factory cooler and use only the stand alone LP4590 due to the fact that I may have metal debris in the factory cooler from destruction of the old tranny. The old tranny had lots of metal in the pan. I have a new convertor also and I plan to run a clean flush on the existing cooler lines with alcohol. Do you guys think this tranny will be ok with the stand alone cooler.
What is the best way to install a temp.gauge?
