SignUp Now!I understand what your saying. That's why you shouldn't use the auto learn in itself as a end all be all. You need to look at the tune and tweak it as needed every so often to interpolate the cells and surrounding cells.
You need to lower the gain values
Lance,
I have a few questions,
1 - Is it preferred to run in Load indexed speed density mode ?
2 - if so, does the remote baro sensor on AUX 3 constantly correct in this mode, not just sample at start up ? (I'm assuming only used in Load Indexed Speed Density).
3 - Is the remote baro sensor used on AUX 3 used in regular speed density mode if its enabled ? (I'm assuming not).
Comment - Help file has an error in 6.2.14, Says Aux analog input 2 (should be 3).
The problem is it don't correct the 've table.in a manner that would interpolate the surrounding cells. It dwells on changing one ve cell...
Example I had a square of mid 60's and after a few blasts down the track I had like a 22.
I will look and see if I saved that file so I can post a screen shot of it.
1. In most cases, yes. Especially if you need optimum performance over a range of altitudes (If you live in Denver, def. yes).
2. Yes. In load indexed speed density mode, the load is calculated continuously from the remote Baro and MAP. If a remote Baro sensor is not available, the Baro is only sampled from the MAP when the engine is not running. However, the load is still calculated continuously from the static Baro reading and the live MAP reading.
3. The remote Baro sensor is only used for load indexed speed density mode.
6.2.14 is the "Fan Off" parameter description?
Lance,
Thanks for clarifying this for me. Attached is a screen shot of the help file were the error is and in the last sentence of 6.2.14. Not trying to be picky, I just noticed this while I was reading and trying to figure this out before asking in a post.
Allan G.View attachment 226223
DO NOT USE IGNITION CUT WITH THE STOCK IGNITION SYSTEM.
(or the TR6, if you need ignition cut, use an aux output to trigger the 2-step input)
clear enough?
Bob
Bob, can you explain more about this. With the new xfi module that will allow us to use the 2 step 3step etc from the xfi interface why can't we use that? I have no issues using the dip switches In the tr6 but seems like the convince of using the xfo to do it would be better.
Guess I will need to setup the pa to set zero correction while on the 2step. I have it run already to the xfi just need to figure out what the setting is
And probably no change log.Sounds like there's another Flash update from B5 and now B7 ?
AG
AG
I thought I read on the FAST forum that the rev limits didn't work with COP ? If so this will eventually effect me and would like a copy of the flash. It doesn't look like its posted yet.Most of the time, the iterative changes are inconsequential.. B7 fixes an issue with the heuristic traction control in some applications.
