SignUp Now!What your not cold enough yet with all alky?My intake air temps do notYes. I've been playing with the idea of maybe using the AB injection nozzle down track, but that's a test that is low on the list right now.
My nitrous system is 2 separate stages. One stage is the 364 port injected shot. The other is the 50 shot that's injected into the turbine housing.What your not cold enough yet with all alky?My intake air temps do not
start to rise until half track.I was thinking of spraying at the 1/8 but
i run race fuel not alky.My best pass is 9.50 at only 18lbs with a so so launch
i wonder if it would pick up much spraying the second half .I use a 100 shot
to spool.I don't expect the car to pick up too much with a ton of boost
because of the back pressure rising. I think @ 35psi maybe a 8.90.When
i switch over to my gt4788 i would like to run an 8.50 index class with
out being on kill.I would love too get a full season of racing without
a tear down.I can live with that in this poor economy.My local track has about ten events a year for 8.50 index.A few years ago tso cars were known for
all the carnage i think that has come around some.I wonder how many passes the tso guys think they could get at 8.50 without a freshen up.
Did anyone come up with an answer to my fuel consumption figures?
BSFC: 1.15
240 lbs/hr
Methanol: 6.7 lbs/gal
SG: .786
320 lb/hr/cyl with Ethanol? What is your hp target?i was thinking of going over to ethanol i was told i would need 320/hr
capability.Is that the target for your engine when you crank it up.
i had very good short times with my 109.I made to many changes when i wentBill, the thing is if you get the car doing good short times you don't have to run it hard past the 660' to make up time. You should be able to run 8.50's with less than 30 psi and conservative timing and A/F.
I'm not sure what it is you want to know.can you please elaborate on the 50 shot in the turbo housing?
Who was saying my hp was only 800?
That was me. I was saying your rwhp was in the 800's based on your current (lack of) performance numbers. I will be at the West Coast Nationals. If you come, I'll split the cost for you to slap it on Jan's dyno. No more sliderules, sims, or calculators.
It's a complete flow curve that is input. This is the intake.
.100 68
.200 142
.350 230
.458 280
.500 272
.550 303
.600 310
.700 312
.750 312
[Ducking for cover]
