That was me. I was saying your rwhp was in the 800's based on your current (lack of) performance numbers. I will be at the West Coast Nationals. If you come, I'll split the cost for you to slap it on Jan's dyno. No more sliderules, sims, or calculators.
Isn't a chassis dyno just another big fancy calculator?
I've heard it's possible to have different results from one chassis dyno to another. So even chassis dyno results can be questioned when it comes to peak performance numbers.
A chassis dyno is just another way to measure hp. Not so much different than using a sim based on good math, or using incremental data off of a time slip, or... using fuel consumption. :biggrin:
Thanks for the offer, Cal. I have a chassis dyno available to me right across the way in my industrial complex. I have used the service occasionally for customer's cars. The operator is just as anxious to get my car on his dyno as you are, and at no cost to me.
Isn't it true that the tune up changes from engine dyno, to chassis dyno, to the actual track? I don't use any correction in my fuel map and if the tuneup needs to be even just a little different for a dyno pull, I would rather not go through the bother of having to play with the fuel map for that. Not to mention the aux fueling transition timing that is completely dependant on the rpm and map rise rate for the transition to occur without a problem. I can't stress that point enough. If those rates are different on a chassis dyno, due to a different loading than what I get on the track, it could result in a catastrophic disaster. If that point is not clear to you, please let me know and I'll explain it to you. It's the one main point that has kept me from testing the car on a chassis dyno.
I would rather blow the engine on the track, than on a chassis dyno.
