87 T-type that is bone stock and low miles. This will be it’s fourth pump (it’s still working but doesn’t hold rail pressure after you cut if off (no hot start) and rail pressure is a few psi low while running). I’ve seen the 255lph racetronix pump recommended here but based on the descriptions I’ve seen it requires an additional harness. Preference would be to stay as OEM as possible. With that in mind what’s the best/most dependable OEM style pump available today?
AI seems to think the newer GM EP386 pump might be a better option, is that a good choice, will it be plug and play?
Thank you all for your help!
Cheers,
Sorta
Cheers,
Sorta
