the oil filler tube had a replacement cork washer used on it ,this was allowing an unmetered air leak and drove blms up to 145-150 at idle . I cant seem to order one from parts store so i will make one from heat resistant silicone sheeting
This issue caused me a lot headaches and a lot of money. The best solution is eliminate the whole oil fill setup and go with a breather with a billet tube on the valve cover. Brad[/quot
So i take it the breather would only breath to the intake duct not to the outside air at all
You obviously have alot to learn. Valve cover breathers have no purpose being hooked up the air intake either before or after the MAF sensor. Braddeffinately not good an a maf based system (2 breathers venting to atmosphere )
Why are you arguing with me because i posted a known problem and solution ? Where is the post where you let all these guys know you had trouble with this oil spout leaking air to begin with?
i may have alot to learn brad , but im sure i dont want to learn it from you .
