SEALZ
I use the cork one piece gaskets on the pan w/ a LIGHT coat of petroleum proof "smackmasm" on both sides. I then tie the gasket in place on the pan w/ dental floss. Wax'd does best!!
Once the pan's in place and the bolts are started,NOT TITE, the floss is cut and pulled out. DO NOT pull the floss too tite when tying !! It WILL cut the gasket!! Ask me how I know!!
I use the neoprene rear and ft seals. I offset the rear seal halves about 1/8" so the joint surfaces are not in line w/ the main cap joint surface. The seals get a TOUCH of sealer on the ends of each seal where they come together.
I then put a LIGHT coat of silicone, AKA "smackmasm", on the faces of the main cap, paying particular attn to the corners. NOTE that the corners of the cap are bevelled and are a good spot for a leak, especially at 30psi boost!!
DO NOT forget to put some lube on the sealing surfaces when installing. A dry seal can be pulled by the rotating contact surface on the crank and get burned and fail soon after.!!
I have used the "swell up" side seals, [the ones that swell up when immersed in oil], and have also used the rubber ones w/ the drive pins and also filled the slot w/ sealer. If you use the sealer method, BE REAL SURE the air pockets are removed w/ a wet [water to prevent the silicone from sticking to the wire]wire.
They all worked well, EXCEPT the first time when I drove the pins into the wrong side of the seal!!!
RTFD!!!
As for the ft cover, I've used the rear entry rubber seal and had the cover bored for the seal to go in from the ft. [An old Ruggles trik] That way, you can replace the seal w/out removing the cover.
BTW, just redid a pan gasket on a customer car.. Seems he had tried about 3 of the blu silicone gaskets and had distorted the pan so bad it leaked like a sieve! He then took the pan off and beat the "torque limit" dimples down flat and used so much silicone that the pump screen was plugged 50% shut..
Back under my rock
