I have an 87' GN with 39k miles. Here is my mod list:
K&N air filter
LS1 Maf
PT-61 BB Turbo
Stock Intercooler
RJC Powerplate & Boost Controller
60 lb. injectors
Stock engine with 100 lb. valve springs
New coil pack & Ingnition module
New plugs & wires
New Cam & Crank Sensors
Turbotweak Race Chip
110 Race Fuel
3" Downpipe
Vigilante 3200 stall converter
Trans Cooler
MT ET Street Slicks
24 lbs. Boost
40 lbs. Fuel Pressure
This is what everyone told me I needed to run consistent 11 sec. 1/4 mile times. Problem is, I have only run a best of 12.5 @ 106. My O2 readings are super low at 144 idle, and 475 at WOT. O2 cross counts at WOT are 166?! What is up with that? My 60 ft. times are good at 1.67, but once the boost goes over 20 psi. the car just nose dives and sputters out? No knock whatsoever?
Any help is greatly appreciated! I'm sure you guys are sick of questions like this all the time, but I've tried everything I know to do.
Thanks!
K&N air filter
LS1 Maf
PT-61 BB Turbo
Stock Intercooler
60 lb. injectors
New plugs & wires
110 Race Fuel
3" Downpipe
Trans Cooler
MT ET Street Slicks
24 lbs. Boost
Thanks!
