I have spoken to on of the major BW distributors about coming into the Buick Market. He has has two of three of the cars and loves them.
The only issues is he would have to cast his own 3 bolt turbine housing.
To get this process started he would need about $10,000K.
He was not sure that he could get a return on investment with how
many cars were still out there. I considered trying to come up with the money for this for the rights to be the exclusive dealer, but we are trying to by another house soon and I could not justify the gamble.
Are there any constructive criticizms or opinions out there on the BW S400 80mm variant on our cars? I'm looking hard at maybe trying one.
How big are you wanting to go on the 3 bolt housings? :biggrin:
Right now we can only fit up to certain sizes in the 3 bolt housings ~70mm ETT wheel. The rest of the units we can do in T4's if you wish, buyt they are the larger frame stuff. We are working on ETT hybrids...John give us a call.
I just spoke to Jose and he said he could put something together for
us for ~$1000 and going to 1700 for a full custom unit.
The wheels that could be built out first are the 57,
62, 66 and 70.
57MM Flows 62lbs x 10.86 = ~673HP Theoretical MAX Potential ~ 620HP Conservative
62MM Flows 73lbs x 10.86 = ~792HP Theoretical MAX Potential ~ 730HP Conservative
66MM Flows 80lbs x 10.86 = ~868HP Theoretical MAX Potential ~ 800HP Conservative
70MM Flows 92lbs x 10.86 = ~999HP Theoretical MAX Potential ~ 920HP Conservative
It is always interesting to have other options...
What's up Jose?
John, Otto had what I think was an 80mm BW on his car at the nats when we tested the converter. It was a T4 version from someone in Florida I believe. I know it went 151 on one clean pass at 30+ boost. Spoolup with the new PTC was very good. Otto may comment on the specs of the turbo. I'm not sure which a/r he was using.
Dang, we have AL all up in this piece! =)
I was just telling Jose that a 66BB would be interesting
to test with one of your converters...
I have always wanted to check out an ETT Wheel.
Hey man...whats up. Got the beast up and running again?
As for Otto's, yes its a 80mm unit with standard cover though which gives up a good bit of power. Also the exhaust housing used on that unit was the turbine housing from a MP GT45 that was machined for the large turbine wheel. Only problem with that was the turbine wheel extends to far out into the caudal space on that turbine housing. So it interrupts flow. The T6 housing is really the only one to use with the big turbine wheel. The GN's though like our newer style turbine wheel which flows huge air and outspools the larger turbine by a good margin.
Cam should be here today, just got to get it back together to do some testing before ORSCA Huntsville.
I need to swing by the shop. I heard you guys were working on some Buick stuff.
When is ORSCA in HSV? I thought I heard it wasn't going to happen??
Let me know if you need anything.
As for GN stuff.....I have Monk's turbo here, waiting on the dang compressor wheel which has been a PITA to get but should be here tomm I believe. I am also working on getting getting the units in so we can get the Borg Warner GN turbos done.
Jose,
Thanks for your time today.
Can you machine the t6 turbine to work on t4 flange?
I heard this was possible with some of the Airwerks housings.
