out of the loop for while,couple ?'s
stage1gn
Hi all,hope I am posting this in the correct category,I have been out of the loop of vendors,new products ,etc,for a while,still have the car.When I was into this non stop there were vendors such as.....
Bowling Green Customs,ATR,Red Armstrong(Quad AIR),Kenne Bell,Eastern Performance,and Torque Tech.Still see Kirban is there,but can't seem to find Red Armstrong,is he still in the game? as the others.I see a list of all new vendors and suppliers,but a few friends now have gn's and were asking which chip I was running,but like I said I can't seem to find RA,what other vendors are recommended for there chips for these cars now?
Also,for my car,stock motor,tranny ,rear,TA 49 ,stock inj,stock intercooler,stock TB and upper plenum,3'' DP,new valve springs,adj reg.,in-tank pump,3'' TT exhaust,Red Arstrong 108 race chip,volt booster,26x8 MT slicks my best was 12lb boost launch,1.66 60', 12.21 @ 111.44.
Changed to 36 lb inj,big neck on stk intercooler.Would my car benefit from 62 MM throttle body and upper plenum ?
Red is still out there are there are also some new vendors around. As far as getting a chip burned for you try Turbo Tweak. Eric is awsome at burning chips for these cars. as far as the throttle body sure everything helps.
Welcome home! I hanv't used a Reds chip so can't help there. I use a Turbo Tweak chip by Eric Marshall and have nothing but Great things to say about them. I would HIGHLY recommend contacting Eric and he will get you fixed up. Good Luck Jon Hanson
Id skip the 62 mm TB unless you go with more cam and heads and rev to 6000 rpm. No benefit otherwise. Two things i would get asap are a Turbo Tweak chip TurboTweak Home and a wideband datalogger. Both of these new will set you back about $400. I would also get a powerplate for the stock plenum from RJC RJC Racing the leaders in inovative Buick performance will be able to get down into the 11.80's around 115mph in a few passes with these new tuning tools. If you push it really hard at 27 psi and throw a lot of timing at it on c16 gas you could go 11.50's. Id look into alky injection also Alkycontrol.
Bison which wideband logger do you suggest for under 4bills?
LM1 by innovate motorsports. You will need some accessories like bungs or a device to mount the sensor in the tailpipe which is around $100 but it lets you use the LM1 in any car without a bung.
