Anyone else.... feel free to give your opinion as well...... I've had a hot idle oil pressure issue that has been a thorn in my side for some time..... I think I have addressed everything (including rod and main clearances) but the oil pump at this point...... unless there is a crack in the block somewhere opening up bleeding pressure off when it gets hot....
Anyway.... I've not seen the inside of too many oil pumps.... so take a look and see if you spot anything that might be contributing to this oil pressure issue. The pump was recently assembled with the booster plate... the spacer plate... and the longer high volume gears..... IMHO.... It doesn't look bad..... and I should have oil pressure out the wazoo.
