IF YOU WANT TO PAY $24 A GALLON GET AIRCRAFT STRIPPER. LIKE ALL AUTOMOTIVE PAINT SUPPLIES, THEY ARE OBSCENELY OVERPRICED. I'VE USED AIRCRAFT STRIPPER..........THE STUFF FROM HOME DEPOT WORKS JUST AS GOOD (stripease) AND COSTS CLOSER TO $15 A GALLON.
GET YOURSELF THE COARSEST STEEL WOOL YOU CAN GET. NO MEDIUM/COARSE.........COARSE. GET A COUPLE GALLONS OF LACQUER THINNER AND SOME RUBBER GLOVES AND A LOT OF CLEAN RAGS. YOU'LL ALSO NEED A BOX OF RAZOR BLADES. COST ABOUT $5 A HUNDRED AT AUTO PAINT SUPPLY. YOU ALSO NEED A SCRAPER THAT YOU CAN INSERT THE RAZOR BLADES IN.
AFTER STRIPPING, TO GET THE REMAINING PAINT OFF, USE THE COARSE STEEL WOOL, STRIPPER AND THINNER TO "SCRUB" REMAINING PAINT OFF. THEN CLEAN THE BARE METAL WITH CLEAN RAGS SOAKED WITH LACQUER THINNER. YOU CAN USE A METAL PREP BEFORE PRIMERING. I USUALLY SKIP THE METAL PREP. THAT'S UP TO YOU.
If you don't want to spend a lot of money on paint, paint the hood with Nason synthetic enamel with a catalyst. Get a qt matched to your color code. Prime the hood and paint the the Nason in medium wet coats.
DON'T WAIT FOR THE WINTER TO DO IT. THE WARMER IT IS, THE FASTER THE STRIPPER WORKS. HAVE FUN!
__________________
