hi 11's is all im after, i've been a 12.35 as a best so far @ 111.3mph so wanting to do a few tricks to help reach my goal since motor is out & the heads are off! Motor is completely stock except double roller chain, 342 gears, 9" art carr 3000 stall, tranny shift kit, 42.5lb armstrong injectors w/ a 255 tre fuel pump, hot shot kit, caspers volt booster, te-44 turbo, 3" gn1 down pipe w/ 46mm gate, 3"maf w/ translator, ic is stock but front mounted, tt chips for street & race, right side air bag, nitto 275/50 drag radials, alum drive shaft, 3" single shot exhaust.. should be runnin 11's already huh?? no known knock on the caspers gauge. Scanmaster
