Stock valves may work.
H-SPHERE
The stock exhaust valves if back cut will give great results almost as well as aftermarket valves, the intake on the other hand through extensive flowbench testing are not worth using even with a back cut they give up after midlift . Also be careful when selecting after market valves i have tested other brands and some lost as much as 20 cfm . I only use ferrea valves because they gave best flow numbers in the heads that i do.
What I have been doing for a few years now is that I ONLY change the Exhaust Valve to a 1.56`` and leave the stock 1.71`` Intakes. I have noticed the Engines have a better Throttle response and a little more torque.
The 1.56`` I take them from Pontiac V-8 Exhausts. A little Machining is required. But this is much cheaper than buying a set of S/S all around.
Good Luck on your Project..![]()
Joe
