scgnx2
- Jan 24, 2009
Af 03
L8 26
Bat 13.3
Int 133
Bl 160
TPS .44
Iac 12
Did one WOT run, 7 degrees of retard before I backed off
You have an issue, your BLM of 160. The ecm is thinking lean condition and dumping fuel. Which explains your low end power issue.
Re check the translator settings make sure there correct. You were at 119 prior so I suspect the settings.
