1dollardog
Are we there yet?
- Jan 5, 2007
Is a built powerglide any good behind our engines? Found one local with the bop pattern for cheap and was just wandering for a future project. Anybody used one?
SignUp Now!Probably not. The low 1st gear ratio (1.76) will require a lot of stall speed to allow the turbo to spool up. The 3 or 4 speed can use a tighter converter and have better lock up capabilities going down the track/road.
Thanks for clearing that up. It's pretty much what I was thinking in my head but I don't always translate the best when typing.
I have worked with hundreds of customers using Glides with Turbo cars and on a track only car with enough converter stall speed the car will get out and go.
however, one customer sticks out that I remember. He called me and said he was using a Powerglide and one of my 3800 stall conveters. He said with that stall the car would leave right but push through it in high gear at the shift change and by the 1000FT.
He switched over to a T-350 and I tightened his stall speed to a 3300-3400 and the car picked up about 3 tenths and a bunch of MPH.
It was about 1 1/2 years ago but I think it was a stock weight T-type with stock long block 3.8 with a cam, 70 series turbo, front mount and some other stuff.
They did make a few BOP powerglides. I have one.
