JustABuick
- Feb 13, 2013
Hello,
I searched the site and got some help with my powerlogger install, but I still have a few questions.
1.) I am running Julio's TPS harness in order to use the green wire to connect to my analog board...is there a good place on the passenger side of the firewall to run that wire through, or should i run it over to the drivers' side, then back over to the passenger side?
2.) For the PLX wideband, are you splicing into the wire on the bottom right of the "analog" portion of the brain box? 1:42 seconds in the video here http://www.plxdevices.com/Wideband-O2-Touch-Screen-Multi-Guage-p/897346002719.htm or just running a separate wire in there?
3.) are you just extending the white wire from the Scanmaster into the analog board?
4.) Will any of those need to be grounded to the engine?
Thank you,
Kelly
Thank you,
Kelly
