SignUp Now!Just to clarify, there is a 6.0 chip and an SD chip, not a 6.0 SD chip.:smile:
Overall it looks ok. You could probably reduce highway fuel a bit though.
It does appear to be low. You're not accidentally letting off? Your MAP reading also gets weird, jumping up and down. I wonder if something is wrong in the 5v circuit (which would power both the MAP and TPS sensors).
Check the grounds on the back of the head, it grounds alot of things to the ecu. The TPS ground is isolated at pin D12 directly to the ecu, but is shared with the coolant temp and air temp sensor. Log confirms those sensors are fluctuating too. Either bad ecu of ground somewhere is dirty/loose, etc
the map sensor is powered from the dashboard and that voltage is failing in many cars, check that as well
ML
looks like the 12v power to the ecm is bad too, I suspect the voltage regualtor in the alternator is going. Try another alternator.
I looked at the battery voltage its in one of the power logger graphs you can pick. I think its a bad diode or rectifier in the alternator. Those ecm connections are usually pretty clean unless your car leaked water in to the ecm. Wd40 just removes moisture usually, but it won;t hurt anything.
I took a look at the voltage chart and see a drop from 13.9 to 13.1, is that enough to cause a problem? Or cause the type of problems that I could be seeing in my map and tps voltage drop? Im assuming yes. 1 volt drop on a 5 volt signal....![]()
