This turbo is new, I was going to build another motor with new combo.ported heads,roller cam.6262, but its not going to happen this year. I was looking for trade , but if someone wants to make offer it can be bought looking for something around 585 hp - 600hp No stall required. Thanks
The te61 in your sig (if its a 69 or 76 trim ex) will work better than anything mentioned if you run it at 25psi ir higher unless you keep the 6262 and run at the same boost. The 6262 will make more power if you run more boost/rpm.This turbo is new, I was going to build another motor with new combo.ported heads,roller cam.6262, but its not going to happen this year. I was looking for trade , but if someone wants to make offer it can be bought looking for something around 585 hp - 600hp No stall required. Thanks
I sold the te61 when i bought the 6262. I have a ta-49 on my car now at 25# . Will the 6262make more powerand work with stock converter?
6152e is rated at 630,, ta49 is rated at 545
^ i agress with LOL@V8.. i would recommend nothing less then a 3K with the 6262
