Yep, that's because the 6057 is a new model turbo that features a billet compressor wheel. Sorta falls between the TE60 and a PT6131E.
Turbo6Smackdown
The New School charts' suggested stall ratings have been derived from customer feed back and utilizing the latest torque converter technology from PTC. As far as hp differences, they have mainly been attributed to the aerodynamic design of the billet compressor wheels. And speaking of billet wheels, where as one wheel in the past was considered a High efficiency wheel, (IE: it liked to be run at very high boost levels) these new Billet wheels are very comfortable being run at lower boost levels. All of these models listed on the New School chart have useable boost levels of 12psi all the way up to 35psi. Most street cars don't live very long at 35+psi tho. That's not to say that they won't make anymore power past 35psi, on the contrary, they make power up top as well. Exactly what those levels are, have yet to be determined.
The biggest thing we are seeing, or should I say, have customers telling us, is that they can actually turn their boost levels down and run the same times with these new Billet series turbos. This has been the case with both the new 6262 and the 6765 turbos, which have displaced the 6152 and 6776 turbos of the past. And of course if they turn the boost level back to what they were originally running, are making quiet a bit more power.
With these models being very new to the Buick market, it will take some time to read about more results as more of these make it onto peoples cars. Another thing, not many Buick owners out there are all about dyno testing. Most Buick owners that I know personally either play on the streets, or take it straight to the track. Which, in my opinion, track testing is the best method.
I would love to see these tests performed on some real world Buicks. Take 4 cars.
One being a bone stock with fuel system mods of course, make 3 runs. Let it cool completely, remove the stock turbo and install an out of the box Billet 5857E journal bearing turbo and make 3 more runs.
Second car would be a slightly more modified car with basic bolt ons, you know, 3" downpipe, aftermarket intercooler, fuel system mods, a good torque converter, etc etc, and either a PT6131E turbo or a PT6152E turbo. Make 3 runs, remove the turbo and install a new Billet 6262E journal bearing turbo with the wastegate hole ported to match whatever downpipe setup. Then make 3 more passes at the same boost level.
The third car would be a typical full bolt on car with stock bottom end, heads, intake, t-body, plenum, cam, fuel system, good converter, built trans and a PT6776 turbo. Make 3 runs, swap the turbo for a Billet 6765S journal bearing turbo. Then make 3 more passes at the same boost level.
Fourth car would be a TSM combo. We're all familiar with one of those right?
Take the PT70GTQ or PT71GTQ off and install a new Billet 71HPQH turbo and hold on.
These would be 4 really good comparisons, as the main changes are to the compressor and turbine wheel. Not necessarily going from journal bearing to dual ball bearing. But I can say that going from journal bearing to dual ball bearing makes a significant difference in spool up.
I hope everyone gets some good use out of these new charts. I know that my next turbo Buick will be a mid mileage (40-80k mile) stocker with bolt ons, running a Billet 6262S turbo, with ported shroud and dual ball bearing on it with a PTC converter, some 65# Mototrons and a Turbo Tweak chip.
Kinda like this one.
Billet 6262S Ported shroud.
And now, some eye candy...
Billet 6262 with E cover.
Billet 6765S
Drool, Drool.....
Sorry this was so long.
Hope this helps.
Patrick
