Presicion Front mount, TH400 conv. and pistons
turbobitt
Precision Front mount intercooler, very good shape. Sold as Intercooler only with no pipes - $400 OBO Plus shipping
TH400 precision industries 3500 stall converter. Only 10 passes and limited street miles.
$350 plus shipping
Set of used Stage II JE pistons for,
4.00" bore
3.625 stroke
6.5" rod
.927" pin
Double pin oilers
1.2mm / 1.5mm / 3mm ring grooves
Valve reliefs for stage II head
8.5:1 compression
Pins and support rails not included
$300 plus shipping
Crank Hub for internally ballanced engine.
$80 plus shipping
Piston pictures
Picture of pistons
What's the pin height of the pistons and how much of a lift are they intended for? I just might be able to use them.
Pin height is 1.21" and I had about .620 lift with no issues. I don't know what the max allowable lift would be.
Allan G.
Thanks Allen. They're 0.04 to tall for me. Here's another bump for you though.
There may be enough material to remove .040 ". The rings will just be closer to the deck.
$250 for the pistons takes them. They are a really good piston and in good shape.
Allan G.
