I have a GEN 6 DFI system that is reporting a constant "-11.6"  in the MAP field of the Calmap 6.32 View screen. This is regardless of load placed on the motor.
I've tried three different MAP sensors, two 3-bar sensors and a 2-bar sensor. I've traced the wiring all the way back to the ECU several times and had a second party verify it in case I was making the same mistakes over and over again, everything checks out.
Has anybody known of a MAP input to die on the Gen 6 boxes?
Charles Brooks
Charles Brooks
