Ok. So I'm ordering a new pump, hot wire kit for the pump and injectors, ordering 60lb. injectors from turbotweak with a chip. (hopefully to correct the lean out problem i had). I have no cat. dual 40 series flowmasters , stock turbo, stock DP, auburn Posi, 2800rpm redline stall, well built internals for trans. inside i have pro comp ultralite guages with boost, tach, oil, volt, water temp, fuel pres. casper's knock and a scanmaster. oh and probably most important, stock internals on engine. (90k). what are the good and bad of alky? should i or shouldnt i? figured now is the time if i'm orderin a chip anyway
