Mike T
- May 3, 2013
Interesting slide spring comparison.
SignUp Now!Unfortunately sometimes we don't know what happened we can use our best educated guess. My rotor exploded cruising this summer, no reason it had been in the trans for 12k miles.Thanks for the word of advice, I do have a good set of micrometers. Sure would like to know what actually happened rather than just rebuild it and hope for the best.
Great!I took about 150 pictures today detailing what I do to a used pump. It'll have to be its own thread and it'll have to be after this weekend where I won't have Wifi the majority of the time.
Some of the pics are showing the difference between the early and late casting and what changed and why. Others are showing the different pump bushings etc.
Would like to see this too if available. Rigged up a makeshift spring pressure tester and .110 didn't make a huge difference. Would also like to see an update to Daves list.......everything I measured fell short on pounds.As far as heights it looks like 1.5 is full boogie and 1.225 is approx min (off a few thou wouldn't matter for comparison purposes).
I'd like to see:
stock dual springs
Stock dual springs with spacer
Transgo spring alone
Transgo spring with spacer
Transgo spring with stock inner
At both heights if possible. Suppose you could do transgo outer/stock inner AND spacer if you want to get wild and unruly lol.
Great!
LOL I was wondering about that.Sorry Steve, must have accidentally given your post a bad rating by mistake.
IMO "Dumb" shouldn't even be an option in the ratings. Don't think I've every said that to anyone in my life in a serious context.
